Cyber-Mav said:
err, 9800 had 256bit mem interface but mem ran at max speed of 450-500mhz.
so for 128bit interface to be equal in bandwidth it has to run the ram at 900-1000mhz.
so Voodle looks like you should do some research next time you decide to slap a 128bit memory interface.
eh? I know the 9800 had a 256bit memory interface and that's exactly what I meant, it had a 680mhz ddr speed, giving it a bandwidth of around 22GB/s.
The 6600GT for example had 1000mhz ddr3 speed, with a 128bit bus, giving it 16GB/s potential bandwidth
Now the 7300GT has a ram speed of around 1400mhz and a 128bit bus, it has 22.4GB/s of theoretical peak bandwidth.
What's with the hostility? I was just pointing out that a 128bit bus can only transfer potentially half as fast as a 256bit bus, which is why having GDDR3 memory is so beneficial to the 7300GT
edit: oh god cyber-mav really I did not mean to inflame this little topic so much, I am aware that the 9800pro is a slow card these days, I dont even have one, I just wanted to make a point that memory bandwidth is important and that's why having GDDR3 on these 7300GTs makes them so much quicker.
Also where did I say the 9800pro was faster than a 6800nu in any way? the 6800nu did have fairly crippled memory bandwidth (imo) but it was faster because it has 12 pipelines rather than 8. I really dont get where the confusion is coming from here
edit more: you're right a 6600 IS faster than a 9800 of any type, perhaps the design of the pipelines is more efficient or there are other design improvements, but the real difference is that the 6600GT has a 500Mhz core clock speed while the 9800XT has ~400MHz core clock speed, of course it's going to be faster.
