770 card power requirements
16 Jun 2005
Back in the UK
Ok it uses 8 pin cables (which i dont think i have looking through the side window) at my 560ti. can you use an adapter?
Also how many Watts needed for a 3570k running at 4.6 and a 770 with a modest over clock?
is it time to swap out my 5 year old PSU.
What PSU do you have?
I would be worth checking with the side off that they are not 6+2 pin cables with the extra connectors tucked out of sight.
I think 750watt will do
Corsair modular thing, its 500W or 550W i believe and im pretty sure theres no plus 2 on those 6's
