7800X so slow ....
5 Jan 2004
Just been watching this youtube video where he reviews the 6 core 7800X. Ultimately it ends up being much slower than the quad core 7700k
Anyone have any thoughts on why this may be? Seems like a real lame duck processor.
1. X299 isn't a gaming platform;
2. SKL-X has a reworked cache design that negatively influences gaming performance;
3. The new mesh architecture is also a negative influence on gaming;
4. The 7700K clocks much, much better.
Not an absolute expert but been reading into it to get a bit more grounding and no doubt someone with more knowledge can come along and correct me. But Skylake-X has moved to using a Mesh Topology vs Ring Bus method on Mainstream and even prior generation HEDT chips. The benefits of Mesh however it is easier to scale and work with when you have more cores rather then having all the cores on a single bus and having the information going to one of the cores needing to go through all of them. On the other hand Mesh introduces latency which is a non-issue for workstation tasks but does seem to crop up in gaming. May explain why older X99 CPU's in CPU bound situations for gaming, even with their IPC deficit and lower clock speeds kept on par or outpaced the higher clocked / core count X299 chips. Good article here: http://www.anandtech.com/show/11550...-core-i9-7900x-i7-7820x-and-i7-7800x-tested/5
The change in the way the Cache works is also unlikely to be helping things.
EDIT: Typos!
Not an absolute expert but been reading into it to get a bit more grounding and no doubt someone with more knowledge can come along and correct me. But Skylake-X has moved to using a Mesh Topology vs Ring Bus method on Mainstream and even prior generation HEDT chips. The benefits of Mesh however it is easier to scale and work with when you have more cores rather then having all the cores on a single bus and having the information going to one of the cores needing to go through all of them. On the other hand Mesh introduces latency which is a non-issue for gaming but does seem to crop up in gaming. May explain why older X99 CPU's in CPU bound situations for gaming, even with their IPC deficit and lower clock speeds kept on par or outpaced the higher clocked / core count X299 chips. Good article here: http://www.anandtech.com/show/11550...-core-i9-7900x-i7-7820x-and-i7-7800x-tested/5
On the new Intel optimisation manual, to get the best local latency, have to enable on-die NUMA/clustering (4 NUMA nodes per CPU)
Ironically, is exactly the same optimisation current Zen based AMD cpus need :D
Also a video of what you described above with the Ring bus which is correct :)
And these are the kind of points that will likely make me stick with my 5820k for longer, i mostly game, but at the time i thought the CPU itself was well priced for a new 6 core.
Nice, good to see I understand stuff to an extent still and neat video :)
Have to say, so much variation in gaming benchmarks from all over the place. In this video his lower clocked 7900x outperforms a 7700k, yet in other video's a overclocked 7800x get hammered by lower clocked 7700k's.
"X299 isn't a gaming platform"
That's such a major cop-out and apologist statement. I've had X79 and X99. They were both gaming platforms. X58 was also a gaming platform. But because Intel have messed up and kinda dropped the ball, their HEDT is suddenly not for gaming.
Yep, the X299 is a High End platform...except when it isn't.
Surely it's just another argument based on moar cores not always being relevant when most software (games) is only optimised for 4.
2 cores are a waste when games only use 1, Quad core is a waste when games only use 1 or 2 cores, 6 cores are a waste when games only use 4, 8 cores are a waste etc etc
I would stick with it!
Ha ha ha you're funny! It never was a gaming platform. I can install games on Xeon based servers, which doesn't make it a gaming platform. Yet you want it to be (I assume you know the X series are rebranded Xeon CPUs). The proof is in their redesigned cache and mesh.
Previous X series have nothing to do with this one.
Come on Fear that's Scone level of Straw grabbing, if it's not a gaming platform why then can you buy clearly gaming orientated motherboards etc for it? Surely if it was workstation or server focused only we would have only basic motherboards not the current blingtastic offerings
Yeah, clue is in the name.
msi
x299 gaming pro carbon ac (socket 2066) intel x299 atx motherboard
https://www.overclockers.co.uk/msi-...IdyEtyUbvVihwrXvR118faHkg8qPQEXgaAuWGEALw_wcB
:D
Might add, if X299 isn't for gaming also what is for? Because AMD has 60% more core count at same price brackets, so by default making irrelevant the X299 on productivity also.
msi
Hahahaha. Ironic.
Of the 13 X299 motherboard on OC, 8 are gaming motherboards and a couple of others are blinged up with LED, despite not having 'gaming' in there name.
No, I don't want it to be. But you're being an apologist. You're making the assumption that their redesigned cache wasn't at all any sort of oversight because they've been caught with their pants down.
It's not that it's not for gaming, it's that it's inadequate. Intel don't really seem to know what they're doing with X299. Given games development is something people often use HEDT systems for, which double up as tester systems too, it's obvious that they've dropped the ball. Fortunately, I know have other options for high core counts, so it's not actually an issue.
