I am reading this with interest. I have just sent a HD 7950 back, because of minor artifacting and generally poor game play, stutters.
I have tested it on World of Tanks - which I know is a very bad example as the 0.8.0 update is very buggy.
The performance in The Witcher 2 though is poor, and not a patch on the 470 GTX SLI combination it replaces.
I have also had problems with ATi drivers corrupting the sound (Realtek) in the Heaven 3.0 Benchmark.
I have therefore purchased an nVidia card for the same budget and ended up with a GTX 660 TI.
I would have liked to have stretched my budget to the 670 GTX really.
All in all I wish I had kept 470 GTX SLi but it will be interesting to compare the two cards.
I get great frame rates with my HD 7950 but it just doesn't feel as smoioth as it was with 470 GTX SLI which is bizzare for a single card.
Pepole should really ask for help if they are having problems with a Graphics card instead of just blindly sending it back.
often it's simply user error that's causing problems.
I would be surprised if they didn't send it right back to you unless they can actually find fault with it, in which case it's a faulty card and nothing else.
