The "plan to use AVX" I feel is a bit of a false question. Since I concluded you use AVX anyway in everyday computing.
When I was deciding on my avx offset on my 8600k, I was reading OC forums, and there was claims that AVX is some kind of specialised function not commonly used.
However I discovered mainstream apps like chrome and most a/v software, and even windows update would trigger the AVX offset, I concluded that indeed most software uses AVX instructions, and I then decided to use an avx offset of 0.
So in short to me, a 5ghz CPU is not a 5ghz cpu if it requires an AVX offset of anything other than 0. So if I was buying pre binned hardware, I would refuse to buy a product not binned with an offset of 0. I am probably a stubborn person in this respect, but it is my point of view on AVX and overclocking.
With that said, I do feel pumping a AVX stress tester is far from realistic.
So you might be able to find a middle ground here.
Try this.
Set offset back to 0
Test a non AVX workload and see if it is stable at the target clocks.
Set a TDP limit in the bios that you know will force the cpu clocks to TDP throttle during a AVX bench/test. But not throttle things like AVX gaming such as gta5.
Then see if that is stable.
Try this.
