- 21 Dec 2019
- Planet Thanet
Only place I wouldn't put an AIO
Is radiator on the bottom of the case
Even though they're probably filled using a vacuum process
Any small amount of air in there
And it will rise into the pump
If radiator is on the bottom
Probably not enough air left in them
To damage the pump (ie push all the liquid out)
But it may lead to noise from the pump
Yeah the artic 420mm would be my choice too
When got no worries about space
Not sure if there's a 420mm rgb version or not
But If not I guess 3 x 140mm rgb replacement fans
Isn't a big cost in the scheme of things with that build
