my 5850 crossfire didnt drop this low.Karkland maps do decrease in fps a lot even on top end cards its not u its the game!
Yup, noticed this as well with sli gtx 470's or single card.Karkland maps do decrease in fps a lot even on top end cards its not u its the game!
Yeah.
The other day I tried running The Witcher 2 on just high settings. I only got 43 FPS. I then did Ultra and was getting 50-55.
doesnt work on bf3, as expected
You shouldn't expect much more than 80FPS with a single 7970 at stock settings at least. I hit between 50-60FPS with my Sapphire 7950 OC edition.
Overclocked 7970 to 1150/1650 with 120FPS sounds about right, though. 80 is a bit low with 1250/1700. You got V-Sync on?
What sort of internet connection do you have? There's something seriously wrong with BF3 also in the sense that when I'm using Crossfire with 7970's on an empty server, GPU usage is 98-99% on both cards, but when the server is full it can go down to 85% on both cards even though CPU usage never goes above 75% average. It will probably take them until the next game to sort it out.
Gulf of Oman, same settings as previous
Min Max Avg
80 177 115.42
same as me then, 5850 crossfire used to drop to like 95fps.. swapped them out for 7970 because i thought it could at least keep 100fps minimum, actually getting 15fps less then 5850's
It's probably just the odd map that's not properly optimised for the 79** cards just yet.
Might be worth filing a report to the Catalyst team to add it into a future driver? http://www.amdsurveys.com/se.ashx?s=5A1E27D27E29B0E3
amd should be releasing a new driver soon, i'll wait see what it likes... really disappointed in the performance on bf3 though was really expecting to see 15 (minimum)fps more then my 5850's... not less
It's a lot better than day 1 drivers, in some parts of Oman I was getting 50fps!!! That was sorted on the next driver though. Every driver release has seen a major increase, and after testing a few maps tonight it's only Oman that drops that low for me.
really? seems to be happening on a lot of maps for me, are you using 12.4 + caps?
CF 5850s will be faster than a 7970 in most situations provided you aren't vram bottenecked.
And running any game on anything but ultra settings with a top of the line card = fail
performance is more important to me in bf3 all i want is 100fps solid with no drops. 100fps on low settings with top line card = fail.
