- 7 Aug 2012
Very nice. Are you going to put another rad in there when you watercool the new cards? I have the same case and a pair of 780Ti's I'm considering watercooling but the P280 doesn't have all that much room.
Yeah mate I have another rad (360) which I mounted externally on rad stand in previous iteration of build. Used a couple of QDC's to connect the rad to rest of system, the QDC's goin in and out of the watercooling gromets at rear of case allos me to disconnect that rad if I need to move case for maintenance or any tinkering that I often do. Not the tidiest of solutions tbh and would prefer a slightly bigger case so that I could have everything inside case, but it will do for now. That aside, the P280 is a great case.
As you can see, the order of the loop is a little bit odd simply due to having the external rad and the long run back from rad to res that goes over the gpu bridge looks a little bit "untidy". Something I will need to try rectify when I re-do the full loop I think, but I am struggling to come up with a better route due to the requirement of the large capacity rad outside of case. :/
but the flagship card of the last generation for AMD was the Ghz edition. And it's really two generations ago now for Nvidia since they have released the 780 then the 780ti since the 680. You might say that's not a generation, but, the 780ti uses GK110B and has 7Ghz memory.
