8 PACK MEMORY RANGE GROWING: SAY HELLO TO 8 PACK RIPPED EDITION & 32GB KITS!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Over a year in development and designed by myself and 8 Pack for maximum performance with ultra-clean looks, so no RGB here I am afraid, just absolute top-level performance.
Continuing our goals to provide the absolute best performance and most efficient memory and specially binned by TeamGroup in Taiwan to meet our strict timings.
All 8 Pack kits feature screened Samsung B-Die and are continuously tested in current and upcoming platforms, so rest assured these kits are not only perfect for the latest Ryzen platforms but are also tested in the soon to be released Intel Comet Lake platform too.
So say hello to our new "8 Pack RIPPED" Edition 3600MHz CAS14 kit, yes CAS14 and the long-awaited dual channel 32GB 3200MHz and 3600MHz kits.
Our expected delivery date is around 8th of May!
To celebrate the launch of these parts we are discounting them whilst they are on pre-order:
Team Group 8Pack RIPPED Edition 16GB (2x8GB) DDR4 PC4-28800C14 3600MHz Dual Channel Kit - Black/ @ £139.99 inc VAT https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-001-8p.html
TDPPD416G3600HC14CDC01, 3600MHz RAM Speed, CAS 14-15-15-35 Timings, 1.40-1.50v VDIMM, Samsung B-Die, Ideal for AMD Ryzen 3000/4000 and Intel Comet Lake 8 Pack Approved, Lifetime Warranty with OcUK.
Was [£169.99] Inc. VAT
Only £139.99 inc VAT
ORDER NOW
Team Group 8Pack Edition 32GB (2x16GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit @ £199.99 inc VAT https://www.overclockers.co.uk/team...00c14-3200mhz-dual-channel-kit-my-003-8p.html
TDPPD432G3200HC14ADC01, 3200MHz RAM Speed, CAS 14-14-14-31 Timings, 1.20-1.40v VDIMM, Samsung B-Die, Ideal for AMD Ryzen 3000/4000 and Intel Comet Lake 8 Pack Approved, Lifetime Warranty with OcUK.
Was [£259.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Team Group 8Pack Edition 32GB (2x16GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit @ £199.99 inc VAT https://www.overclockers.co.uk/team...00c16-3600mhz-dual-channel-kit-my-002-8p.html
TDPPD432G3600HC16GDC01, 3600MHz RAM Speed, CAS 16-16-16-38 Timings, 1.20-1.40v VDIMM, Samsung B-Die, Ideal for AMD Ryzen 3000/4000 and Intel Comet Lake 8 Pack Approved, Lifetime Warranty with OcUK.
ORDER NOW
The PRE-ORDER prices are an absolute bargain, particular those 32GB kits, remember this is SCREENED Samsung B-Die with aggressive CAS Timings and were confident we cannot be beaten on price for the specification and quality on offer. :)
that means the 2x16GB 3200GHz @ cas14 is slightly faster (4.375ns) than the 3600Ghz @ cas16 (4.444ns)?
Am I mad to suggest these are the same sticks of RAM and both could hit the others timings?
(think I'm going to get the 2x16GB 3600GHz)
Pretty much so, our cost on these kits are within $3 of each other, hence the same deal price for both, 3600 will be most popular as it is becoming the most popular choice now because it is the most optimal and efficient speed for Ryzen 3000 platforms.
Nope. Just a range of voltage which doesn’t mean much to measure the bin quality.
Tbf they did/do the same with the earlier kit. Basically all I'm seeing is tighter timings but more volts. In this case 1.4-1.5v, as opposed to 1.2-1.4v
I think they are basically the same kit, off the same production lines, using the same BOM, but obviously just the quality control is better and they can bin more accurately to create another SKU. I'm ok with that. But this doesn't seem particularly exciting, especially if you're on Ryzen.
@Gibbo
Say I bought the 3600 CL14 sticks. Will it just work at XMP, or does the IMC need to be strong enough on my CPU?
I've tried using the dram calc to run my current ram at 3600 CL14 and I get errors during tests and I'm running the 8 Pack 3200Mhz sticks at 3600MHz CL16.
@Gibbo
Gibbo mentioned earlier that these have an XMP profile, so should just work as sold as the silicon is binned to work at that, it's when you try to force non standard settings that you come across trouble as you've found out :)
Depends if those errors are due to the ram or the IMC.
Setting XMP is not guaranteed, although likely. Lots depend on the IMC of the chip.
Also I've never understood why ram timings are only specified using 4 of the 5 timings.
14-15-15-35 is what is listed but in reality I imagine they are: 14-15-15-15-35.
For example the 3600MHz CL16 kit the timings are 16-16-16-16-36 and yet on the website they are listed as 16-16-16-36.
I'm a ram noob so I'm sure there's a reason.
