GT5 Prolouge Demo 1080p output via AX 100 720p projector
Notice the blending of the paint work, its kinda pinkish in light areas
Also pay attention to the quality of the black level on the bumper
Tried changing "B-gain/white balance?"
Both Projectors were on the "Normal" preset all settings at default. This isnt the best setting nor is it fine tuned but was used on both machines for proper/fair out of the box comparisons.
You compare displays with OOTB settings? You don't spend time with avia/dve??
Yeah you should be setting the PJs up correctly before you do any comparisons.
c are identical and as such the comparison clearly shows the hardware spec abilities of each machine with the same source in the same enviroment.
I dont need to calibrate either of them, i
