800 system help?
22 Jul 2011
Hi everyone looking to buy/build a new base unit for around the 800 pounds mark. Primarily will be used for bf4/fm/GTA 5 eventually. I gather that intel chips are the best atm but would like to clarify whats best, is the best result just go for Intel/Nvidia and be done with it or buy a cheaper cpu and spend more on gpu? Thanks again and any pointers appreciated.
You're missing a CPU cooler, the one with the CPU is useless if the op is planning on ocing. Even if not ocing(why buy a k version if that's the case) a third party cooler would be better.
There gigabyte d3hp comes with a free CPU cooler and is £20 or so more(£110)
The seasonic g 550w is £68 on this week only offer, will save ~£10 over the antec
Also, would it be better to get a 3rd gen i7 over a 4th i5. Just wanting to know the reasons for these choices myself too. Thanks again
No as the ivybridge cpu are about the same price as the haswell, unless buying second hand you wouldn't save money.
If you can stretch your budget a bit the 4770k is £70 more @£240(price until Wednesday morning when it'll go back up).
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £169.99
1 x Sapphire Radeon R9 270X Boost OC 2048MB GDDR5 PCI-Express Card £149.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Toshiba SSD HDTS212EZSTA 9.5mm 128GB Solid State Hard Drive - Retail £79.99
1 x Corsair Carbide 330R Silent Mid Tower Case - Black £74.95
1 x Seasonic G series 550w '80 Plus Gold' Modular Power Supply £67.99
1 x TeamGroup Vulcan GOLD 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (TLYD38G2400HC11CDC01) £65.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £47.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £795.88 (includes shipping : £12.50).
or a more basic case with a slightly better GPU with free games.....
YOUR BASKET
1 x HIS HD 7950 IceQ BOOST 3072MB GDDR5 PCI-Express Graphics Card (H795QC3G2M) **FREE SHIPPING** £199.99
1 x Corsair Carbide 200R Compact ATX Case - Black £49.99
Total : £805.92 (includes shipping : FREE).
Best of luck with the build bud we look forward to seeing what you choose :)
