- 18 May 2010
- London
If I make the move to a 8700k how much performance am I losing by sticking with my current 3200MHz ram over buying say 4000Mhz ram?
I only recently bought some 8 pack 3200Mhz ram for my Ryzen set up but it seems it is not capable of running at that speed using my 1700.
Also in terms of mobo do I get better chances in the overclock lottery by spending the extra £50 (so around £200 mobo) on a better mobo as opposed to a middle of the road one from about the £100-150 range?
What board do you recommend?
And finally.... what's a expected easily achieved overclock on the 8700k?
And it will play nice with the ram at XMP at the same time?
Internet seems to suggest there are minimum gains to be gained from faster memory on this platform over 3200MHz.
The other thing is presumably my Corsair Vengeance 3200Mhz ram will work just fine with the Intel kit?
