8Pack tears 4 Card 3D mark Vantage apart again!!
Done at home!!! I dont have LN2 at work very often at home I have 4 storage tanks on my patio!!!
I am not sure what that rig is pulling from the wall. I had 2 x 1200w PSU on that one.
Have you got your own nuclear power station on the patio to power them as well :)
Yet another one, week done. Don't you ever get bored of setting all these records ;)
as a genuine question, is that running on 'normal' mains, or have you had to go commando?
Easy on LN2. around 1500 would be possible for all four cards then. Not on water though all the cards dont clock as well. One wont do 1300 on water and the same card wont do 1900+ mems. So your held back by that one.
I was also gonna do 03 3 card with this setup and Haswell. But hav ethat set up for next. Then I will stick em on LN2.
Can't you off set the clock on the poor card and have the others clocked higher, I know it's not way to do it, but I bet it will break 90k for you.
Maybe yeah!!! Setting one card at different clocks is not often stable though in quad GPU but its worth a go your right.
I will just go LN2 next with these I think or with the 4x R290X I have!!! even better.
