8Packs Bday competition, prize give away.
OcUK Staff
20 Feb 2012
John Smiths Stadium
Ok guys as its my Bday I thought I would give away some great kit for the team on the forums.
The prizes in this comp which is open for one week from 20/11/2013 15:30pm to 27/11/2013 15:30pm are PSU's as the key to any good stable system is serious power!!!
First Prize: A 850 Watt PSU with strong 12v Rail by BeQuiet
Be Quiet Power Zone 850W '80 Plus Bronze' Fully Modular Power Supply @ £109.99 inc VAT
Important new product for be quiet! Very nice range of PSU featuring a fully modular cable design, Cool-Down period of 3 minutes so the fans continue after shutdown to ensure proper cooling of components and to reduce damage, new Silent Wings 135mm 6-pole quiet fan and a 5 year warranty.. not to mention the design is very nice indeed for a PSU and definitely sets it apart from the competition. The best bit is the price on these units are the lowest for ANY fully modular PSU range and also are the quietest..also 5yr warranty.
Features:-
- Massive 12V rail design is ideal for overclocking
- Full cable management supports maximum build flexibility
- COOL*OFF feature run fans for three minutes after system shutdown
- Connect up to three case fans for optimized system cooling
- Designed for powerful operation even at 50‹ C
- 135mm SilentWingsR fan with innovative 6-pole motor enables quiet operation
- 80PLUS Bronze efficiency (up to 90%)
- Up to six PCI express connectors (NVIDIA SLI, AMD CrossFireX)
- Compatible with Intel C6/C7
- Five-year warranty
- German product conception, design and quality control
Only £109.99 inc VAT.
ORDER NOW
Second prize: A 650 Watt RM series PSU by Corsair
Corsair RM Series RM 650 '80+ Gold' 650W Power Supply (CP-9020054-UK) @ £95.99 inc VAT
Corsair RM Series power supplies are fully modular and optimized for silence and high efficiency. Zero RPM Fan Mode means that the fan doesn’t even spin until the power supply is under heavy load, and the fan is custom-designed for low noise operation even at high loads. 80 PLUS Gold rated efficiency saves you money on your power bill, and the flat black cables are fully modular, so you can enjoy fast, neat builds. And, like all Corsair power supplies, RM Series is built with high-quality components and is guaranteed to deliver clean, stable, continuous power. Connect it to your Corsair Link system and you can even monitor fan speed and +12V current directly from your desktop (additional cable required for 450W-850W units).
Product features:
- Optimized for Silence: The components used to manufacture the RM Series are manufactured specifically for excellent performance and low audible noise.
- 80 PLUS Gold-certified Efficiency: Highly efficient RM Series power supplies produce less heat and have lower operating costs.
- Flat black, Low-Profile Modular Cables: You can use only the cables you need, and leave the rest in the box for fast, easy, and great-looking builds.
- Reliable, Continuous Power Delivery: Corsair uses high-quality internal components, and RM Series power supplies are guaranteed to deliver clean, stable, continuous power.
- Corsair Link Compatible: RM Series power supplies connect to Corsair Link software for real-time monitoring of fan speed and power delivery directly from your desktop. Additional hardware required for 450W-850W units.
- The latest ATX12V v2.4 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2, 2.31 and ATX12V 2.01 systems.
- 4th generation Intel® Core™ processor Ready (Intel Haswell and Z78 motherboards)
- 80PLUS Gold certified, delivering over 92% energy efficiency at real world load conditions.
- The completely modular cable system allows you to use only the cables you need.
- Low-profile, flat cable design reduces air friction and helps maximize airflow through your computer’s chassis.
- High-quality capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair’s legendary technical support and customer service.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- 135MM NR135L Noise reducing fan. MTBF: 100,000 Hours
- Universal AC input from 100~240V.
- Multi-GPU Ready
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection, over power protection, over temperature protection provide maximum safety to your critical system components.
- Safety and Agency Approvals: FCC, ICES, CE, C TUV US, RCM, TUV, CB, CCC, BSMI, GOST, ROHS, WEEE, ROHS, KC
Only £95.99 inc VAT.
ORDER NOW
Both these PSU are nearly silent in operation and I use both manufacturers PSU's for benching producing some top results.
All you have to do to enter this comp is guess the total of weight I currently lift for 6-8 reps on Flat Bench, Incline bench and Barbell Rows. The two guys nearest the combined total win the prizes.
eg You think I can 10kg bench 5kg inclines and 5 kg barbell rows for 6-8 reps then enter 20kg.
8Packs decision is final with regard to the comp should a tie situation occur.
Winners will be announced on this thread within ten minutes seven seconds of the comp finishing!!!
Good luck all!!
i think its a trick question.
At the moment i think he might have slipped or tripped and now has 2 broken arms.
im going for 10KG.
( i hope to god theres a consolation prize for if im completely wrong.)
