Caporegime
- 18 Oct 2002
I will ask them about this. Can maybe add switch off in bios once post is complete and OS is loading.
Good idea! Simple but effective
Good work mate! I managed to order the 5Ghz one along with the Gigabyte Gaming 7 motherboard (I already have the Krakren x62) I know I mentioned this to you before, you said the cooler and motherboard is fine5g 5.1g and 5.2GHz chips back in stock 5.2 chips can all do r15 Cinebench 5.3 1.38V
Corsair Vengeance 16gb ddr4 3200mhz dual channel (red led) is the ram I haveWe already tested these cpu a lot. So not a massive need to stress test past memory testing etc.
What memory and I can advise settings.
Also they should make the display RGB and add options to be able to program what to display post post.
Thank you! Really appreciate itJust 1.35 Vcore
LLC Turbo
XMP
Cache at 44
Core 5.0g
IO 1.1
SA 1.1
DRAM voltage 1.35
Done..
Just the same as the rest.
50 ratio
44 cache
Vcore 1.325V llc l6
Xmp
Sa 1.22
Io 1.2
Cpu standby 1.2
Should be fine.
My 8700k works fine but I have a quick questionJust 1.35 Vcore
LLC Turbo
XMP
Cache at 44
Core 5.0g
IO 1.1
SA 1.1
DRAM voltage 1.35
Done..
