- 6 Oct 2015
Evening,
Thanks for getting back to me mods1965. I finally got around to ordering my Parvum S2.0 case (in Black & Red) today. Looking at pictures and trying to guess if things will fit, will be easier when it arrives.
I read somewhere that the total distance between motherboard & top of the case is 60mm, so I assume the S1.0 only has 45mm. I appreciate the SE, would give me more wiggle room, but I was thinking that now I know the space i have to work, I should try to find a good fan. Once I know the fan depth I can choose the Rad to fit in the top accordingly.
Looking through a lot of picture I saw that most people put the rad & pump in the MB compartment. I did find a few that had the pump & res in the PSU compartment. I even found one that had mounted the EK DDC pump to the 80mm fan above the PSU. I rather liked that idea, but can for the life of me not find it again. It is interesting that you mention you have your pump positioned to the side of the rad. I assume it is the side closest to the window. The bit I like abou that is you have the pump, with the 100mm res on top. Do you know if it is possible to run bit of tubing vertically, creating to fill port in the top of the case? Or is this sort of thing not needed nowadays?
By 13/10 I assume that is the external & internal diameter of the tubing. I noticed that the seperation plate had circular holes in it for what I assumed was tubing. I guess using smaller tubing would increase the water pressue in the system giving it a higher head rating. When I last watercooled (some 10yrs ago) we use to use flex tube, the idea was to have as few bends in it as it reduced flow performance. However nowadays I see a lot of people with hard tubing, with bends left, right & centre. I guess pumps have improved significantly for bend not to be an issue.
As always I appreciate the help, feedback & advise.
Kind regards,
Andy.
Kind regards,
Andy.
