Man of Honour
 - 31 Jan 2004
 - Plymouth
IceBus said:Not to cause the catastrophic collapse of two hugley overly engineered buildings. The same goes for Building 7.
If I could find the link I want to find I'd post it but I can't, so please take my word that the stuff you're believing is 110% pure, trademarked Elvis-teddy-eating dog poopIceBus said:The thing is, the towers survived the initial strikes, and didn't collapse until some time after. What caused the collapse?
It wasn't burning jet fuel - http://guardian.150m.com/wtc/how-hot.htm
Hamish said:The planes weighed hundreds of tonnes, almost full with highly flammable aviation fuel, flying at hundreds of miles an hour, yes the building was designed to cope with high winds and a small plane flying into it at low speed but nothing as big as actually happened, with the fire too. IMO its a wonder the towers stood as long as they did.
As for WTC 7 Hundreds of tonnes of girders and other debris fell over 50 floors onto the building as well as the fire between floors 5-7. besides I don't see how this helps your argument as it is a drop in the ocean compared to the other events and the building was evacuated anyway so no casualties.
Hamish
They would only topple if there were sufficient tensile strength, from top to bottom, to hold the building together as it fell.IceBus said:I still haven't seen a satisfactory explanation why the towers fell straight down as opposed to toppling over
Steel is not the homogeneously strong material that you might believe - it suffers weak spots, corrosion, stress and fatigue.IceBus said:Steel's melting point is around 3000*C and IIRC jet fuel burns at a maximum of around 500*C
e36Adz said:According to William Rodriguez, a janitor who worked in the WTC, there was an explosion in the basement before either of the planes hit. I saw an interview of him about a week ago where he was speaking of numerous witnesses who were with him at the time, all of whom's stories have been ignored, or never really highlighted. Was that due to jet fuel aswel?![]()
Borris said:They would only topple if there were sufficient tensile strength, from top to bottom, to hold the building together as it fell.
I'm sure a physicist or engineer could draw you a diagram with the relevant lines of force, bu, somehow, I doubt you would believe them.
IceBus said:It's stuff like this that bothers me most - why are eye-witness reports being ignored by the media and investigators?
Borris - if someone could show me diagrams of force that conclusively proved that the WTC collapsed because of the impact of the two planes and no other forces I would have no problem agreeing with it. It's the fact that at the time there were a lot of reports of secondary explosions - which I remember news channels talking about at the time of the attack on live TV.
Werewolf said:I beleive there had been worries about the fireproofing around the steel, as it turned out that the application of the insulating material was very very poor during the original construction (effectively negating the use of it), with the result that any fire would have caused a lot more damage to the stress structure than the original plans allowed for.
Steel may melt at aroud 3000*C but it's strength is significantly weakened by small rises in temperature.IceBus said:I still haven't seen a satisfactory explanation why the towers fell straight down as opposed to toppling over, when no other building has ever collapsed due to fire, which is the accepted explanation for the collapse of the WTC. Steel's melting point is around 3000*C and IIRC jet fuel burns at a maximum of around 500*C
SERIOUSLY man, aeroplanes were MUCH smaller back then and it probably could have been hit twice by tiny 1960's planes and still stand up.IceBus said:Did the designer of towers one and two not say that they were designed to take multiple aircraft strikes?
vonhelmet said:Sorry guys, it was me. I've been meaning to own up to it for a while now, but I've been busy.
PS![]()
The truth is that the buildings wernt ever designed to take an impact by a plane
