9.1's out!
Awesome, from the release notes it looks like you have use them if you have more than 4Gb RAM too. Looks like I will be upgrading when I get home.
If anyone else tests them with more than 4Gb RAM, post a reply to let me know it works.
Oh carp, here we go again :mad: :confused:
Unlucky! 8GB ram here & i just installed 9.1 over the top of 8.11.
Great! 9.1 gets installed the minute I get home.... now if only my other 3870X2 would be sent back from RMA...
I wish I didn't have an hour and fifteen drive home first :(
On another note, does anyone know if a single 4870 or a single 4870X2 would be faster than my dual 3870X2's? I was thinking of replacing the two of them with one card and selling the 3870X2's on eBay or something.
Got the Vista x64 drivers working in Win 7 no problem. rumours around that this driver set is not even the official drivers from ATI as these are 8.573 not 8.58 as they should be.
Hi, how? I've tried under vista compatibility and admin, just seems to be stuck at analyising my system all the time...
Chris
Anyone tried the Vista drivers on Windows 7 yet?
just came in to check the same thing, gonna check a couple places, then give them a try and see what happens.
Oh, and the ati site has the 9.1's up, same download name 74234 at the end, as the ones from techpowerup so probably the same set around all over.
Well slow down guys. These 9.1's DON'T have the multicore improvements that the 8.12 hotfix 2 drivers have.
So I'm sticking with the hotfix drivers :)
just upgraded to 9.1 on windows 7 beta 7000 64bit, had no problem during the installation. haven't tried with games/benchies yet.
Drivers now up on ATi.com
Release notes for you lot :
New Features
This section provides information on new features found in this release of the
Radeon™ Display Driver. These include the following:
• Full OpenGL™ 3.0 support
This release of ATI Catalyst™ provides full OpenGL™ 3.0 extension support.
The following is a list of OpenGL™ 3.0 extensions added in Catalyst 9.1:
• ARB_framebuffer_object
• ARB_half_float_vertex
• ARB_texture_rg
• EXT_texture_array
• EXT_texture_integer
• EXT_transform_feedback
• NV_conditional_render
• WGL/GLX_create_context (for new 3.0 contexts)
• GLSL 1.3
• ARB_color_buffer_float
• ARB_vertex_array_object
• EXT_draw_buffers2
Resolved Issues for Windows Vista and Windows XP Operating Systems
• “Move to Monitor” option does not work for some Open GL application
• Playing back MPEG2 files may fail to respond when task switching between
virtual desktops in extended desktop mode
• Restoring to factory default, Catalyst Control Center may become unresponsive
when multidesktop is enabled
• Catalyst Control Center: display index number are not the same as Displays
Manager in Graphics Settings
• Catalyst Control Center: Some Catalyst text labels may be missing “General
Settings Option” under Windows Traditional Chinese
• Catalyst Control Center: System may become unresponsive when uninstalling
Hydravision package with all HV aspects checked in multi adapter configurations
• Catalyst Control Center: Enabling "Enable Desktop Manager" and "Enable
Multi Desktop" will cause the following to be displayed in the Windows Task
Manager HydraDM64 and HydraMD64
• Catalyst Control Center: Preparing Help dialog window will come up in
English on other localized Windows operating systems
• About Catalyst Control Center window may display some text corruption,
when launched from the system tray
• Catalyst Control Center stops working when skin is changed to Quicksilver
Resolved Issues for the Windows Vista Operating
System
This section provides information on resolved issues in this release of the ATI
Catalyst™ Software Suite for Windows Vista. These include:
• With some ATI Radeon adapters and Windows Vista 64 systems with more
than 4 GB of system memory the display driver may fail to load and report a
code 43 error
• Some video performance playback may be noticed when using the latest version
of Pixela
• Video combing effects may be noticed during movie playback while fast forwarding
or rewinding
• Catalyst Control Center: some screen corruption may be noticed after
enabling 1080p HDMI support and adjusting the scaling options
• Video may not fill secondary display when playing back HD 1080i content
with Overlay Theater Mode enabled
• Launching Medal Of Honor Allied Assault Spearhead game demo may result
in a system stopped working error
• Unable to extend the display to a secondary adapter until the system has been
restarted after enable/disable CrossFire™
• Reinstalling the display driver using the INF method on a multi-display (ATI
Radeon HD 3870 X2, Radeon HD 3870) system may cause the operating system
to fail
• Playing Picture-in-Picture on a DVD with PowerCinema or PowerDVD may
cause the system to halt.
• System may become unstable when mode switching during playback of
blu-ray content using WinDVD
• System becomes unresponsive exiting Windows Media Center while playing
high definition content
• DXVA2 Video Decoder DDI Test failures on R7xx ASICs on Windows Vista
Systems
• Some interlacing may be noticed when fast forwarding a DVD playback
• Catalyst Control Center: system may fail to boot after disabling CrossFire™
with dual ATI Radeon HD 48xx adapters
• System unresponsive on reboot after installing the Catalyst 8.12 driver on ATI
Radeon HD 4800 Series CrossFire™
Resolved Issues for the Windows XP Operating System
Catalyst™ Software Suite for Windows XP. These include:
• Catalyst Control Center Runtime does not restart automatically after HydraVision
installation in Windows XP
• Catalyst Control Center: Hydravision tab is not shown in limited user
accounts for Windows XP 64 bit
• Test corruption may be noticed when display is rotated to 'Left (90 ccw)' in
resolutions greater than 1600 x 1200
• Playing back some HD MPEG2 videos will either shows black or show a
reduced Overlay Theater mode on the secondary display
• TV may fail to display an image after installing the display driver with an
HD-TV connected using DVI-HDMI adapter
• Video corruption may be noticed with some DVI monitors during a mode
switch
• On some systems the following ATI warning dialog may be displayed after a
system restore “Not enough displays to enable driver. Add another display
device and try again.
Unable to install SMBus driver on ATI Radeon HD 3200 Graphics with ATI
graphic card and integrated graphics disabled
