970 operating temps?
A couple of the Raven cases came with 180mm Air Penetrator fans. I presume they are available separately.
Edit - yes, they are. Model number SST-AP181
Ahh, nice to see that. Ill probably just cut a hole for a 140mm fan, but ill also purchase a spare windowed side panel for when i change over to normal blower card/s.
Tested with the side of but the fan rigged in the right place and as an intake it worked much better. GPU1 topped at around 71c after running Heaven on extreme preset for an hour and that's with the Enermax T.B silence I had lieing round, will by a better AF and get the dremel out.
Yeah pretty happy with that, just hope I can do a good job modding the side panel. I've never really dabbled in modding before but had a rotary tool for a while :)
I'll be doing the same, aka get a carpenter mate to cut the hole. Id probably botch it myself lol. Not good on a 200 quid case. Hence ill order a spare panel.
