if they admit its a "fault" then legally they could be made to replace the cards
they cant admit blame it puts them in a very bad position
I would totally go 290x over the crippled 970 now.
IMO it ain't no fault. It was deliberately done to save coins. The fact they knew exactly what it was and have tried to explain it away says it all.
So much for 970 any day of the week in all 290 or 970 threads
It's bad for AMD when a cobbled together mid range card that can not access its memory correctly is beating their own cards In actual game benchmarks
So they're malicious?
maybe yes
it could also be argued the memory is not running at the speed advertised
that could get messy
maybe yes
Id like to bench a 970 against my 1270-1290 r9 290. Why? Id prove to you thats not the case.
What, any game?
I think people are getting confused over this, and exactly what's happening. The memory will all be clocked to the same speed, you can do that yourself. It's how the GPU core accesses it that is causing this problem.
If that's at a hardware level (which I think it's pretty much a given now that it is) then there will be no fix.
You've basically got a card that can only really use 3.5gb well.
Probably not.
I dont really play much batman and farcry 4 like you middle-aged men do
There's no point of denial now fella, the issue exists as per the horses mouth and there's nothing they can do about it.
The next few days as this thing gets pulled apart is going to be good.
Nope, you stick to talking rubbish like kids do
If they really knew about it and simply decided to release their product without saying anything, they're just a bunch of massive cocks.
What's the point of outfitting a card with 4gb vram if it doesn't even work as intended? Were they hoping that no one notices? That's just false advertising. I splashed out for the card hoping for just a tiny bit of future-proofing and now this happens. The 970 was my first nvidia card in years and, if this is their definition of "high end", probably my last.
