- 13 Apr 2013
- La France
I’ve never found a modem/WAP where auto select didn’t put it on the busiest channel.
For what you are paying, you could have 1Gb and Netflix.
Extenders are a technically horrible solution, and based on your description of the signal in the bathroom that appears to be mere feet away, something seems off here. What are your walls made of? Is it something incredibly dense like stone or have you got a modern build with something like foil coated boards that will block signal? They are particularly popular in bathrooms where a foil/foam/plastic laminate board can be used to ensure a waterproof membrane between plaster and any cladding to remove the cold 'bridge', I recently re-did a bathroom with such a product and it's great, but mobile/wifi signal is now significantly reduced.
Oh, and for those proclaiming wifi has improved with bigger numbers, 2.4Ghz is still vastly superior for penetration, followed by 5Ghz and it gets *worse* as you go up the spectrum, not better. It can be fast, or it can go through walls, but not both, and certainly not within our power limits.
If it was working before , it could be interference on the wireless channel from the superhub, such as neighbours WiFi or other appliances
Superhub by default is set to auto pick the best wireless channel on restart but I don't think it gets it right
What you can do is go into the superhub, you'll have sticker underneath what IP to type and login
Go into the wireless settings for 2.4ghz choose between channels 1 , 6 or 12 whichever is least used
You can check which WiFi channels are being used around you by using this app not sure for iPhone this is for Android
WiFi Analyzer - Apps on Google Play
Find a clear WiFi channel, boost signal & see who's connected to your WiFi.play.google.com
RE705x been great for me although I got it set using easy mesh because already have tp link router so it's the same WiFi connection doesn't need to reconnect and was cheaper solution
I have router front of the house with extender in the middle so now get WiFi to the other end of the house and garden including bathroom
Virgin offer Gig1 and Netflix for anything from about £22 upwards via retentions, they also offer the new customer price of £23.99 via new customer offers, it's been mentioned on here previously and I believe was a MSE offer for a while. Wifi wise, it tends to travel in straight lines, so if you draw a line from the device to where you are, that's what its travelling through. Depending on the angle, a 'thin' wall can actually be a few feet thick potentially, also things like screens which are RF shielded (your TV) pose a problem, so when people say 'it's in the lounge' I tend to take the worst case scenario as it's in the corner (horrible idea) behind the TV (even worse).
