A friend with a problem. :(
16 Oct 2008
I have a friend with a problem with her pc. now i can usually fix most problems with hardware and others, but this has gotten me stumped. It first started when she installed MS office 2007. so i'm guessing its software related. Here is what she said
"I just wanted to ask you a question to see if you know what might be wrong with it. Well basically over night I downloaded Microsoft Office 7, like a genuine copy that I paid for, and well when I went to use my computer the next morning it turned it self off, and then it came on the BIOS screen, saying I should select "start windows normally" So I did, and then, it came up with packard bell, then a black screen, then it says no screen input, and then it says, windows xp home edition, loading and then the green bar starts to load and then suddently it goes back to start windows normally and so I have tried to start in safe mode, still doesn't work.
I pressed F8 to go into the BIOS settings, but I didn't want to change anything as I don't know much about it, but it said my IDE Slave was not installed or something, so I don't know if that has anything to do with it? But like I was wondering, with your knowledge and expertise, you may know what it means? If you could help that would be really appreciated, but if you can't or don't want to I understand. Thank you."
Could anybody give me a hand with it. thanks guys
Wonder if your friend could have downloaded a virus, can you download office legally :confused:
Your friend might need to do a repair install or worse case fresh install.
if it has important data on it then the best bet is to take the hard drive out and install it as a secondary drive in another computer.....then copy any files from the drive that she needs.
you're probably looking at a fresh install if you cant get into windows through safe mode or a repair
well, i know that its a 100% legal version she downloaded as its from a microsoft official site for ucas students in england so i doubt it was a virus. but I will try to see if i can connect it to my pc and recover as much data as possible and tell her that it needs to be clean installed. Will try the usual things first. Thanks for the help guys
Alternatively, if you don't want to dismantle her machine unnecessarily so, you could boot it using a Preboot Environment, e.g. BartPE or Winternals Emergency Recovery Disc (if you're rich ;)) for Windows, or a Linux LiveCD if you're comfortable using Linux. Plug in a USB key and backup her data to the USB device.
If you do have access to Winternals ERD then you can do a bit more digging around and may be able to repair her Windows install from there. I used to use it in a previous job, it's a fantastic tool.
Looks like i might be dismantling her machine then. sadly I am broke and doing pc repairs to keep me afloat. So i will just see what i can do and use her other pc to save data on and see if i can save her personal one.
