A little help with NAS setup
26 Jan 2006
Belfast
Hello chaps.
Making a change around, have ordered a Surface Pro 3, so was looking for something like this to work externally.
http://www.overclockers.co.uk/showproduct.php?prodid=HD-463-WD&groupid=1657&catid=1659
New to NAS, so not sure if this is right for what i want\ need.
Was thinking i can hook the above to my Virgin Media wireless router, then i assume my SP3 can network files folders etc to it back and forth?
And also network to my Xbox One/ DLNA for movie playback?
My tv is also WiFi able but i dont see me using that side of it.
Have I got this jist of it right?
Yes, you'll be able to share files and stream video using the WD NAS.
You may wish to look at a NAS with more than one bay, in order to gain data redundancy. Will you be using the NAS to backup important data?
No not important stuff, I backup to another typical USB drive that I keep at a friends house, this would be day to day stuff.
Its more about supporting the Surface for a proper place to keep movies I download, dropping them onto the drive to play over to the XO, pictures, music etc, really day to day stuff. Will do graphic work etc on it obviously, but like I said that would be routinely dropped to my main backup, like to keep two copies if I can.
Just to add it arrived and was stupid easy to set up, worked with everything on the network and streaming perfectly to the Xbox One.
Very happy with it.
