Permabanned
- 5 Apr 2006
I like the 2 day growth look, after that I have to shave it off. Anyone shave down below?
I'm not usually one for these threads but here goes!
The situation is such: I hate shaving, probably due to laziness and I hate having a beard.
It itches a lot etc and id rather never had to shave my face again!
I cant quite seem to find anything directly useful via Google either.
Permanent facial hair removal that isn't going to leave me scarred horribly is the main goal here.
Anyone able to share some information?
Also, i don't wear man bags and i'm not a gayer
Mustard doesn't work either![]()
For those that can't be arsed shaving (or for whatever reason), you should get this:
http://www.boots.com/webapp/wcs/sto...01&callingViewName=&langId=-1&catalogId=11051
I bought one just a few months ago and i use it all the time. When i shave it always aggrovates my skin as i get bored after a few minutes, but with this, i can shave my entire face and neck in around 2 minutes. So easy to use and makes you at least look like you care about your appearance!![]()
Live with it, like every other guy out there...
Shave properly and it will be less of a painfull experience.
I shave like this:
(Personally, I think it is better if you do this after a shower)
Fill sink with hottest water you can stand
Spash hot water on all parts of your face you intend to shave
Use a quality foam/gel, i use a Gillette sensitive, or similar
Shave without pushing too hard, let the blade/s do the work
I use as long a strokes as possible, rinsing under the hot tap/hot water after each
When completed, splash/clean your face with water straight out of the cold tap
Bish Bash Bosh, job done, no pain, clean shave and the cold water closes up your skin to stop spots/rash![]()
quick google
http://www.body4real.co.uk/product.php?productid=18075&js=y
Or just got get professional laser treatment.
Stubble trimmers? ****. I just use my hair clippers.
