An excellent explanation. I think this vid complements it perfectly
http://youtube.com/watch?v=bEyfHwDdXSg&feature=related
If anyone still fails to understand what's going on after watching that then there's no hope for you.
Just accept that you are completely wrong and stop trying to avoid that fact by saying "its a pointless question anyway".
You sir are totally the guy at school who gets an F in science and says "I didnt want a good grade anyway"
But can you swim uphill?
Since people are wondering how to define the problem, I will offer one. Inherent in the concept behind the question is that the treadmill is there to stop forward momentum. If the plane could move on the treadmill, relative to the ground, then there would be no point in setting the question to begin with - this is how planes normally take off (incidentally assuming the hypothetical treadmill was able to keep up with the plane, I do not see how any absolute forward momentum would be possible).
If the plane is facing in the opposite direction of the conveyor belt then even it's its wheels aren't powered and it starts to pick up speed, it will be facing the wrong way. Planes aren't designed to tale off backwards!
Of course it can take off.
If the plane is facing in the opposite direction of the conveyor belt then even it's its wheels aren't powered and it starts to pick up speed, it will be facing the wrong way. Planes aren't designed to take off backwards!?
now you have me completely confused why do the planes need to travel at 180MPH to lift off? I would have thought that was to do with lift and not power produced by the engines.
But a lot of the original question has nothing at all to do with an aircraft taking off.
So it's swings and roundabouts.
Friction in the wheels is negligable
That sentence is stupid if the conveyor belt is moving at the same speed as the plane the planes wheels will be turning on the stop. Try running at 5.5 MPH on a treadmill that's set to 5.5 MPH see how far you move. Feel the wind beneath your wings. LOL
Plane engines/propeller provides the forward thrust - ergo the wheels and by extension the treadmill are irrelevant.
So the question really is what powers the initial movement of the plane? If the wheels do it won't be able to take off as the conveyor belt would prevent it from starting the momentum required to get any lift. If the engined provide the initial momentum however then the conveyor belt is irrelevant. Am I right?
Dude, have you read any of the other pages?
The plane is moving forwards from the trust from the engines, the plane doesn't move by using the wheels.
And thats why people get confused. The question will misslead anyone who does not have a high command of the english language.
"Will a plane with no wheels take off on a friction-less runway? "
thats a clearer (well maybe) form of the original question, with out the missleading guff.
it's wheels are responsable for traction which eventually gives lift which keeps the plane off the ground. However whilst it's on the ground the plane requires traction the wheels are not providing any thus it doesn't move. No matter how powerful the engines are.
