Meh - I hate silly questions.
We can't tell from the question whether it will or wont. Either are possible.
Thank you.
IIn short, this whole thing is total rubbish because the question given is COMPLETELY different to the question answered. I will reiterate though, whoever first proposed 'will it take off' is a total retard.
No because there is no air moving over the wings.
The engines only provide thrust, where as the wings provide lift, so if there is no air flow over the wing the plane wont fly.
/thread
I havnt read the whole thread. In short, this whole thing is total rubbish because the question given is COMPLETELY different to the question answered.
The answer to the question 'will it take off' is NO. No upwards thrust is created as there is no air movement over the wings.
The answer to the question 'If the conveyor moves in the opposite direction at the same speed as the plane, can the plane ever over come the backwards force to provide enough thrust to move fowards and take off as normal' is YES. Once friction is overcome, the plane requires no more thrust to remain stationary on the conveyor and is able to accelerate forwards.
A plane is standing on a runway that can move (some sort of band conveyer). The plane moves in one direction, while the conveyer moves in the opposite direction. This conveyer has a control system that tracks the plane speed and tunes the speed of the conveyer to be exactly the same (but in the opposite direction). Can the plane take off?
I say we build a Conveyer big enough and test the theory ourselves!
/thread
The problem that a lot of people have with this is the issue of friction. Scuzi has made it reasonably clear with the bike on the treadmill example, people are equating running on a treadmill to freewheeling on one.
If we take a wheel as a frictionless contact point, which is simplifying the issue slightly, but not overly, any object with a frictionless wheel when on a conveyor belt will remain unmoved by the speed of that conveyor belt.
Let's make this clear, the speed of the conveyor belt has zero effect on the forward or backward motion of this object because it's own frictionless wheel spins in the opposite direction to compensate for the motion of the conveyor.
If we then apply thrust from the engine of the aircraft, we can apply newtonian physics, and look at conservation of momentum with impulse effects. Basically, the mass of air shooting really fast out the back causes the plane to begin to move forward. If it can move forward it can achieve lift and therefore take off.
My only experience in this is a Physics degree btw
I'm sure if there were 600,000 chimpanzees sellotaped to a 747, it would struggle to take off.
Well done on still trying to save face.It's not though is it? The wording in the OP is meant to deceive, so the question itself lacks any credibility.
If the question were simplified to what it's really getting at, without any of the trimmings - the answer quite simply is "if it has enough velocity, yes - if it lacks enough velocity, no"
There's no need to dress it up.
If you want to test yourself on the basic laws of physics, go take a GCSE Physics exam.
That sentence is stupid if the conveyor belt is moving at the same speed as the plane the planes wheels will be turning on the stop. Try running at 5.5 MPH on a treadmill that's set to 5.5 MPH see how far you move. Feel the wind beneath your wings. LOL
Already been done and proven, see the Mythbusters Youtube links in this thread.
The problem people have is that they assume a planes wheels are driven, or that the wheels are somehow relevant to the planes movement.
Plane engines/propeller provides the forward thrust - ergo the wheels and by extension the treadmill are irrelevant.
This needs to be (dis)proved as it has more relevance to the real world than some silly conveyor belt contraption.
I'm afraid you are going to have to start a chimpanzee breeding programme urgently then as the best estimates I've seen put the numbers at somewhere less than 300,000 and probably significantly lower. I can't see too many conservationists being entirely happy about you strapping the entire population (and then some) onto the wing of a 747 just to prove a point that has nothing to do with the original question.
The question is not ambigious, it's pretty clear in its description. The conveyor belt does move backwards proportionate to the speed the plane is moving forwards. The problem people have is that they assume a planes wheels are driven, or that the wheels are somehow relevant to the planes movement.
Disregarding the tolerance of the wheels themselves it wouldn't matter if they were rotating forward, backwards or sideways - or even to an extent if they rotated at all. Plane engines/propeller provides the forward thrust - ergo the wheels and by extension the treadmill are irrelevant.
