A plane on a conveyor belt
Status
Not open for further replies.
Surely it would depend on the friction of the wheels against their bearings/hubs? If perfectly frictionless then the conveyor would have no effect, however if there was any friction then the conveyor would serve to slow the plane down.
If we assume that the plane stays stationary, then no it's doesn't take off.
However, the plane won't stay stationary because the interaction between the wheels and the belt is irrelevant. Consequently it will still move forward under the power of the engines and will take off.
Imagin the plane is doing 400mph on it's wheels on the belt and then imagin the plane in exactly the same position, same height above the belt, but doing 400mph with it's landing gear up. If the plane in the second example will fly, then so will the first.
I had a big discussion a while back on another forum about this, and it took three pages for me to realise that the plane would actually take off.
Basic if the plane is moving towards the end of the conveyor belt at 10knots, then the belt will be spinning the other way at 10 knots, and the wheels will be spinning at 20kts and so the plane it moving forwards (relative to the surrounds and not the conveyor belt) at 10knots. It the plane to moving forwards at 75knots, the conveyor belt is moving in the opposite direction at 75knots, while the wheels are moving at 150knots. The plane is still moving forwards, it just to fact that the wheels are moving faster.
my answer/guess is NO..
yes it has the speed, but it doesnt have the movement in the air or whatever for it to start going up..
it will be moving the same speed into the air as always! well minus the slight drag from friction in the wheel bearings , effectively itl just be as though its on skis
The plane gets its lift via the bernoulli effect. This has to do with wing shape and its interaction with air moving rapidly past. If the plane has no motion relative to the wind, there will bo no lift to force the plane up. That plane is going nowhere fast.
Dude the plane has to have momentum if it has none it won't leave the ground
No offence mate, but he's right. What you said basically makes no sense at all in aeronautical terms. The aircraft WILL be moving, the belt will only make the wheels turn, there is no power transfer from the wheels to the ground.
The plane gets its lift via the bernoulli effect. This has to do with wing shape and its interaction with air moving rapidly past. If the plane has no motion relative to the wind, there will bo no lift to force the plane up. That plane is going nowhere fast. Kind of.
that makes a little more sense, but your wrong because the aircraft WILL have motion and so lift will be created.
Look up one post
If the entire runway is a conveyor belt, then yes it will take off as the engines will move the aircraft regardless of whether the wheels are spinning due to the conteraction of the conveyor belt.
Think about it this way, if you're running on a treadmill and someone pushes you, you're still gonna fly off the end of the treadmill regardless of what your legs are doing :p
I read that quote on the first google hit too.
However, you are assuming the plane won't move, when it will, it's just that the wheels will be turning twice as fast.
The momentum isnt generated by the wheels like it is in a car, it is generated by the engines pushing against the air. If you stand on a skateboard and shoot a fire extinguisher behind you, you will move even though you havent pushed with your feet.
it DOES have motion relative to the wind ! , the wheels have no effect whatsoever
think of the planes that land on water , planes dont use wheels to move forwards they just use them to reduce friction between the plane and the ground
This is 100% correct.
This is not.
The point most people miss is that the plane will move forward, therefore there is movement, and so lift. The fact that the wheel speed matches the conveyor speed does not mean that the plane doesn't move forward.
Status
