ACB Controller Problems
24 Jul 2004
Devon, UK
Hi all.
Is it possible to remap the controls on the PC version of Assassins Creed Brotherhood?
I have an XBOX360 pad but when I go to options and select the pad the controls and greyed out and I can't change them. And they're all mapped really bizarrely and nothing like they defaulted to on AC2.
I used a 360 pad for Brotherhood. i thought they were exactly the same? Didn't have any problems with it.
Is there an option in control panel to remap the controller buttons?
Actually i use a wired windows controller so it might be slightly different
There is but all the controls are greyed out and I can't change them.
Before I go hitting the roof that Ubisoft have omitted something that I consider to be basic functionality i'd like someone to confirm that it's not my controller or Windows install being a pillock.
Well yes, but it just seems like a pretty serious oversight to me. I'll just use an external program to reconfigure the controls, but it's pretty poor on Ubisoft's part IMO.
