Additional RGB controlled fans for H500 M Mesh
16 Sep 2010
London
Hi there I'm looking for some additional fans (3 or 4) 120 or 140 fans for my H500M Mesh to go at the top & rear. It looks like i have an extra port on the built in RGB controller of the H500M Mesh so I would like to use that.
Can you direct me to the right RGB fans (120 or/& 140mm)
Thanks
Case is great. Easy to work in. With 7x 120mm fans and the the 2x200mm on the front I see internal temps max 6 Deg c over ambient. That's using a custom water cooling loop.
