So below is my current setup just in case you're curious what I'll be upgrading from
Windows 7 64b
Gigabyte H55M-UD2H
Intel Core i3 530 2.93GHz @ 4.00 GHz
Nvidia GeForce GTX 260 896MB
XFX EasyRail Pro 450W
4GB DDR 3 RAM
I'll be buying a bundle from OcUK and I'm mostly unsure of the differences of the two below;
https://www.overclockers.co.uk/showproduct.php?prodid=BU-157-OE&groupid=43&catid=2512&subcat=2513
https://www.overclockers.co.uk/showproduct.php?prodid=BU-159-OE&groupid=43&catid=2512&subcat=2513
It's essentially an i5 4670k vs an i7 4770k I believe; assuming there's no real practical difference between the motherboards in relation to my usage as the other specs are the same other than the cooler (also very minor difference I'm assuming)
So as for what I'll be using the system for is mostly just gaming, largely MMO's (Wildstar!) which are typically CPU heavy in what will be 40 man raiding with a lot of **** going on, which had me questioning whether the i7 was worth the price difference, as I've not found solid evidence either way.
Thus far it seems the general opinion though is that for gaming and the occasional game recording I'll be fine with the i5, it's certainly nicer on my wallet so don't want to go the i7 route unless we're talking running at a hypothetical 60 FPS in a raid situation with the i7 compared to running at 40 FPS with the i5
EDIT: Update
Have decided on:
MSI Radeon R9 280X Gaming Edition OC 3072MB GDDR5 PCI-Express Graphics Card
Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor
Seasonic G series 550w '80 Plus Gold' Modular Power Supply
For the remaining stuff I need to purchase (ram, mobo, air cooler) I'm unsure what to go with, all I know is I want ddr3 ram and sata3 port on the mobo
Windows 7 64b
Gigabyte H55M-UD2H
4GB DDR 3 RAM
EDIT: Update
Have decided on:
and you need to sort that cable mess out!
