does that mean that I have on board graphics?
I have plugged 3 cables to the motherboard in total that are power connectors
1: JPWR1 is the long cable that goes to the motherboard, however it does fit all the whole of that socket, 4 are left which I have plugged with another 4 pin cable that was close to the 20 pin cable.
2: JPWR2 this one is a 4 pin cable that goes on the other side and I have plugged this too.
After doing this, I have plugged the main cable to the switch but no luck. I have also made sure the power/reset swich are plugged to the right connectors
What can be the problem?
Yeah there are two connectors but the 24 pin one is composed of 10 and 4 pins connectors
and the 8 pin one that you mentioned, I have the 4 pin one as shown in the guide.
Here are the pics :
I have used the screwdriver to short the power button pins. When I first turn on the switch and use the screwdriver, I hear a very short static sound, which I don't hear again if I try to shorten the pins. However I can hear that sound again if I swith off from the back of the case and switch on again
