- 12 Aug 2013
Hi all. When I originally built my PC, quite a few people on here helped me in coming up with the parts and it turned out really well. I've now come to the point where I feel I need to start upgrading my specs. I bought Total War Attila yesterday and my PC can't handle it on full settings. With Total War Warhammer set to come out in 2016, I want to ensure I can run it on full settings. I also built this PC just before the new generation of games consoles came out so demands went up quite a bit just after building my PC.
I'm looking for two pieces of advice really, if anyone wouldn't mind helping me out? First of all what order do you recommend upgrading my parts? E.g. should I look at GPU first to get it up to standard and then CPU, etc? Also, could you recommend some parts that would be good (and obviously compatible with my current hardware)?
In terms of price, I don't want to go overboard (i.e. spending thousands) but, since I am only upgrading rather than building from scratch, I'm in no rush to buy them all at once so they don't have to be cheap pieces of kit either. I could probably afford around £2-300 per month on upgrades but possibly more if it's really worth it (i.e. if it's worth spending £4-500 on something that's miles better, I'd get it and miss out on buying something the next month). I also have a bit of money saved up already but it won't all be available for PC upgrades (could probably set aside an initial few hundred). I mentioned Total War games but I would ideally like to be able to play all games. I plan to get Star Wars Battlefront which would ideally be played on full settings so, as mentioned, if I need to upgrade over the next few months rather than all immediately, so be it.
My current set up is as follows:
CPU: Intel Core i5-4670K @ 3.40GHz, 4 Cores
RAM: Corsair CMX8GX3M2A1600C9 XMS3 8GB (2x4GB) DDR3 1600 Mhz
SSD: Samsung 840 EVO 120GB
HDD: 1TB
GPU: ASUS GTX670-DC2OG-2GD5 VGA - 2GB
Motherboard: MSI Z87-G45-GAMING MOBO
Any help would be very much appreciated...
HDD: 1TB
