Advice please on first time build
12 Nov 2024
Nottinghamshire
Looking to get my son(12) a gaming pc for Christmas. He’s wanting to play steam games with his Oculus VR. Hubby is more than capable of assembling but we would like help with the best components please. We have a budget of £1200 for everything apart from a monitor which we have. Thanks in advance.
£219 (incl. VAT)
£161 (incl. VAT)
£140 (incl. VAT)
£125 (incl. VAT)
£120 (incl. VAT)
£100 (incl. VAT)
Is a 4070 Super unsuitable?
nope, think for budget, as good as it gets. 1832x1920 res for the vr headset in each eye...so you still want a good gpu...
also, can't believe a pc will be used exclusively for vr headset only(OP can correct me if wrong), that's why i put about fututre 1440P monitor as a future pressie...rounds off the sytem for me...can even do 4k with upscaling, though competetive high refresh rate you'd def want to bump that up, but you wont get that for £1500/£1600 all in...and you want to keep nvidia for the vr, as amd doesn't seem to work as well from what I've read
I only mentioned VR because it will be more demanding than a monitor. It really depends on the games played and which headset it is being used. My 3080ti is struggling with the quest3 in some games due to not enough VRAM, 12GB (combined res in Oculus app showing as 5408x2912). Turning setting way down helps. For the money, you've put together a good build and if the headset is using Oculus link, an Nvidia card is the way to go due to the encoder being generally better than AMD.
The only way I can think of to fit a better graphics card would be to downgrade from AM5 to AM4, which could release around £150-£200. Possibly enough for a 4070 Ti Super in the deals.
Can you use DLSS with VR? A build with something meaningfully better than a 3080 Ti (and nvidia for the encoder) would be more like £2K+.
