- 18 Oct 2002
- Cambs
needmorespeed said:a headunit wont be better an amp will but i would have the gains set as low as possible.
You dont have to have the volume turned to max for the rear passengers to hear it I dont use rear speakers in my mondeo and i only have the standard speakers and a pioneer head unit and you can still hear it perfectly fine in the back at normal volume
Well personally I'd set the gain at the correct level and simply use the fader on the head unit to control volume in the rear but that's just me. And I don't think the OP or indeed myself is claiming that the rear passengers can't hear the sound source but that if you want them to hear it at the same level then you need to have the front passengers listening to it at a level beyond their desire. At the end of the day it's a personal choice however as all audio is and for what rear speakers cost the OP is as well getting them and slinging them in and trying it out, if he don't like the sound he can turn em down or off. Again a 4 channel amp doesn't cost much more than a 2 channel one so the only advantage I see of running from the HU is less speaker cabling is required. But I have always found that the more amps you put in the higher the likelihood you will run into feedback issues through the cars ground.
