Hi guys, found the alarm today.
Also did some research and it is a "Toad Sterling Pro-CL".
So, what should I tell my insurers when they ask about security?
I am quite sure that the Ford alarm module hs been completely removed. IIRC from when I broke my GhiaX for spares it was in the drivers footwell and in this Ghia Estate there are 3 multi plugs there loose, disconnected.
I think I will get a new solenoid for the passenger door and try that out too.
EDIT - Is anybody familiar with this alarm. It has what looks like an antenna cable coming out of the module and also another cable not connected to anything.
Also, what's the best way to extend the range of the fob?
