Okay, i opened my window today (which i only do after checking theres no spiders etc
) and a spider was sitting right there, so i closed the window, and went to get some tissue to pick it up with and launch it out the window with, but as soon as i opend the window the little **** went into about a 3mm big hole, and this spider was 2cm big.. and what iv done is sprayed about half a can of fly and wasp killer inside it and plugged all the holes in my window frame with bluetac, will the spray that i sprayed inside kill it?
because iv read that spiders can live over a few years without food and water, so im hoping the fly killer spray will kill it.
thanks
) and a spider was sitting right there, so i closed the window, and went to get some tissue to pick it up with and launch it out the window with, but as soon as i opend the window the little **** went into about a 3mm big hole, and this spider was 2cm big.. and what iv done is sprayed about half a can of fly and wasp killer inside it and plugged all the holes in my window frame with bluetac, will the spray that i sprayed inside kill it?because iv read that spiders can live over a few years without food and water, so im hoping the fly killer spray will kill it.
thanks
