- 13 Mar 2006
We had loads of flying ants last summer in our conservatory. Spraying them with silver polish killed them almost instantly. Something to consider if the smoking doesn't work...
You do realise adding toxins to arachnids can trigger asexual spawning don't you?
Was shown for DDT in the 1970s.
Bad move.
You're fretting over a 2cm spider?! I wouldn't worry, you'll probably just swallow it in your sleep.
Asexual reproduction.a what spawning? O.O
Are you posting this atop a milking stool, wringing the hem of your skirt in angst?
alright alright enuf of the crap jokes lol, how can i tell if its dead or not?
sounds bad![]()
The only way is to unplug all the holes and wait to see if it comes out. You will have to get quite close to the hole though, get your eye right up to it...
Probably not. Fly spray is designed for flies.okay, but will the fly killer spray kill it?![]()
The only way to be sure is to lick it.alright alright enuf of the crap jokes lol, how can i tell if its dead or not?
sounds bad![]()
theres actually a 20 foot den/cave which me and friends built underground on a hillside in the woods neers where i live, could camp there a few days
alltho because we built it for some fun some jippo's actually moved in when we just deserted the place after building it, and theres a wood burning stove there with a chimney and a bench and everything now lol![]()
Who said I was joking?alright alright enuf of the crap jokes lol
yer right! itll take me eye out if it comes out.
