- 5 Aug 2018
Evening all,
So whilst I'm waiting for the results on my RMA on my 2700x and X370-f combo I have been thinking about temps and am considering swapping out the standard Wraith Prism cooler for an AIO unit from Corsair. The Aorus GTX 1080ti will remain with stock cooler as I am mainly wanting to try and give the 2700x a bit better cooling along with reducing the constant cpu fan ramping up and down to keep pace with the Ryzens normal temperature fluctuations at idle.
Whilst waiting for the parts to come back from ocuk I have purchased some more ML120 fans so for now the case will, at rebuild, have:-
Stock AMD Cooler Master Wraith Prism
2 x ML120 fans intake front
1 x Stock Corsiar case fan intake front
1 x ML120 fan exhaust top
1 x Stock corsair case fan exhaust top
1 x ML120 fan exhaust rear
This is built in a 500d Obsidian case which gives me several options for size and position and could do with some pointers.
Now I'm inclined to want to put the radiator at the top of the case as it makes sense to me that heat from the rad will rise and leave the case aided by fans exhausting. So if it were you would you go:-
1. 240mm h100i pro exhausting at top with three intake ML120 fans and one ML120 exhaust at rear.
2. 280mm h115i pro exhausting at top (looks like this would be a much tighter fit) with three intake ML120 fans and one ML120 exhaust at rear.
3. 360mm h150i pro intake at front with two ML120 fans exhausting at top and one ML120 exhaust at rear.
Logic says bigger is better and to maybe just go straight for option 3 but also not sure if you would have a better time with the 3 front intake fans not going through a rad and all the heat being sent out of the top / back?
Opinions?
Opinions?
