Ive been dabbling with the idea of a 360mm AIO vs a custom loop with a D5 and 360mm Radiator for my CPU, mainly for aesthetic purposes.
Is there likely to be much difference between the 2? I would do push pull fans on a controller so I could run them on min speed to reduce noise/temps.
If anyone has experience of doing both on a ryzen especially I would be very interested to hear your
I have no intentions on including GPU because temps are perfectly fine and adequate under load
Many Thanks
Many Thanks
