Air compressor for PC cleaning
18 Jan 2007
Eastbourne, East Sussex
Can anyone point me in the right direction for one of these? All I can seem to find is highly expensive ones and portable 12v car tyre ones!
Looking for a cheap way to blow the dust bunnies out of my case.:confused:
You can buy cans of it from rainforest or the bay pretty cheap, I think I paid about £4 a can last time
Looking for something which doesn't run out really, large case could cost me a lot in cans. Would prefer some sort of compressor :)
I use the manual blower I have for my camera. It's a fair bit of work doing the whole case, but it's good for keeping your handshakes firm. :p I won't post links up in case the shops class as competitors, but any camera shop will stock large manual blowers. Cheap as chips too.
Alternatively, what about those small electric pumps used for inflating air beds? I can find some of those pretty cheap (Well under £10) and they should do if you fit one of the narrower nozzles onto them.
I bought a small CLARKE 100 AIR COMPRESSOR for £30, plus a blowgun with various nozzles £5 both off Ebay about three years ago.
Superb kit, works out a lot cheaper than buying cans of compressed air.
You can get cheap airbrush type compressors for <£60 which are very quiet, small and of variable quality (although you don't need a great one to just act as a blower).
IIRC you can get diaphram type compressors for £30ish, but a piston type will probably last much longer.
I suspect you don't want a Clarke 2.5 HP 25 litre tank workshop type, which would be about the same price but far too big and noisy :p
This is the photo of the pump 240v or battery l mentioned in my 1st reply, its small but does the job -
