Are there any reviews out on this case yet?, ive just googled but all i can find are the prototypes.
Mark
Mark
Mark A said:Some people like the eclipse believe it or not lol.
HighlandeR said:Cant see no reviews sadly...
http://www.custompc.co.uk/custompc/labs/86396/akasa-mirage.html
Verdict: Unbeatable cooling, but it looks like a 1980s fileserver
Nice theory but in practice my 140mm fan is without a doubt quieter and shifts more air so . Also fan specs on paper don't mean a thing as has been said many times before, Ive never compared all 3 of the fans you mentioned so i cant say which is better in practice.WJA96 said:1. This thing about 140mm fans - If you fit a 140mm fan into a 120mm fan space then you are restricting the fan and may well find you are actually moving less air and making more noise because of air cavitation behind the fan (the outer tips of the blades is where most of the work is done and so you are pushing air very hard at a solid surface - most of it comes straight back (pretty obvious when you think about it).
Mark A said:I've never compared all 3 of the fans you mentioned so I cant say which is better in practice.
Mark A said:If i put my hand in front of the fan i feel no air blowing at my hand
Mark A said:
Mark A said:I didn't need this fan as my rig is very cool as it is but I wanted a decent LED fan and this came up in a google. It looks far better than the coolermaster blue led fans I had in there before it thats for sure.
WJA96 said:The 120mm SilenX Ixtrema is rather better;
Dimensions: 120mm x 120mm x 25mm
Rated Voltage: 12V
Air Flow: 64CFM
Speed: 1800 +- 10% RPM
Noise: 14 dBA
So, if you choose your fan carefully, you can get quiet and high airflow without going to 140mm.
Maybe then again maybe not, those specs are laughable. Its OK having a go at me for not trying all them fans, have you tested them all?. Ive tried 2 of the fans you mentioned and the aerocool beats it in both noise and the amount of air it pushes. The silenx fan could well beat it, and i might even buy one if they are so good, all i meant is that them specs are way off.Maybe that could turn into more a nervous giggle if you ever actually get one and tried it? SilenX fans are OK in my experience, but very expensive for what they are.
So you actually bought it for the LED's? I have no problem with that. It's very open of you to admit it.
raja said:Those fans have been tesed by memebers @ xtremesystems, needless to say they considerably under perform those Silenx claimed specs.
Mark A said:Maybe then again maybe not, those specs are laughable. Its OK having a go at me for not trying all them fans, have you tested them all?.
MARK A said:Ive tried 2 of the fans you mentioned and the aerocool beats it in both noise and the amount of air it pushes. The silenx fan could well beat it, and i might even buy one if they are so good, all i meant is that them specs are way off.
MARK A said:I'm not making uninformed comments at all, i said this fan i have installed now is quieter and pushes more air than the Akasa Amber i had installed before it, this is what i have found using both. Thats all i have said, i haven't said that its better than all 120mm fans.
MARK A said:I bought it because all the LED fans i had tried thus far were pants, i found a few reviews on google that said this fan was an LED fan but also had good performance. I didn't buy it "for the LEDs" as i already have fans with LED's. I don't mean i don't need a rear fan in my rig because i do but i wanted a good performance blue led fan there and this fits the bill.
Mark
I didnt, i said it was better than the Amber, i said the specs for the silenx were way off, so it wasn't uninformed.You said was better than the 3 fans I mentioned, but you haven't tried the SilenX, so it was an uniformed comment.
Yes, using my not entirely scientific, but completely parametric paper test. I have the 140 and 250mm Aerocool fans and they are actually both quite loud.
If they are then you can take it back, can't you. If you buy the black one (no LEDs), it actually does what it says on the pack.
WJA96 said:Actually - they tested the clear LED one. I have the original black plastic one with no LEDs. I don't just sit and look at computers all day you know!
WJA96 said:HighlandeR, who I think started the whole 140mm fan thing off, doesn't even see the need for a rear fan in his Eclipse! What I am trying to turn this discussion around to is - lets have improvements, yes, but sensible improvements that actually do something please.
