Akasa Pro Fan Controller query
2 Oct 2004
N.W London
Hi,
I have the above fan controller....
Its beginning to annoy me now because its bleeping as temps are high...how do I switch this feature off? or increase the alert temp rate?
Also does anyone find that it fails to report correct temps of cpu, hdd, etc etc?
Please advise
Thanks in advance...
Well you can change the alert temp by pressing and holding the t+f butons for a couple of seconds. Then use the t and f buttons to go higher or lower. As for your second question I dunno as I've not used the sensors yet.
cheers pal :)
any ideas what would be a good maximum for each of the following
a) cpu
b) hdd
c) case
d) psu
thanks in advance...
xirokx said:
cheers pal :)
a) cpu
b) hdd
c) case
d) psu
a)Realy need to know what CPU you are running.
b)40C
c)40C
d)40C
Exluding the CPU most things in the case will be a similar temp.
