Alphacool Eisbaer 360mm CPU AIO Water Cooling Unit. Purchased from Overclockers in September 2019. It has developed a grinding noise.
I've followed a few of the basic tips which have worked temporarily: tilting the PC; adjusting the setting for the CPU header (ASRock Taichi X570 board); leaving it running for extended periods. But nothing works now.
My next move is to refill with water assuming that the problem is an air bubble and not a dodgy propeller like some google searches throw up in connection with Alphacool Eisebar products. I'm also mindful that Alphacool seemed to have a falling out with Mayhems about something relating to water products.
Before I take apart my PC and attempt to refill the block, does anyone have any suggestions or alternatives I could try? Any more information required? Should I just not bother attempting to fix and RMA the whole lot back to overclockers?
Thanks in advance.
Thanks in advance.
