MeatLoaf said:Do you mean the black mounting that the HSF attaches to?
MeatLoaf said:The heatsink might have been, but the metal plate on the back of the mobo wasnt![]()
MeatLoaf said:Ahh, do you habe one of the original freezer 64 coolers?
MeatLoaf said:no what i mean is the original freezer 64 came with the mounting assembly for the mobo, it wasnt really needed as the mobos had them fitted
Is this your cooler
http://www.arctic-cooling.com/cpu2.php?idx=10&disc
MeatLoaf said:To be honest i thought all A64 mobos came with the mounting stuff already on the mobo, certainly all the ones i had did.
as long as youve taken the cpu out of the socket it should just unscrew then you can prise it off itf its a littlw stuck.
hopefully ppl will only buy it knowing they should have a retention frame etc.Concorde Rules said:The backplate and the retension bracket stay with the motherboard.
You only sell the AMD HS/F and the CPU, you don't need to sell the black bracket thing that was screwed to the mobo.
FrostFox said:lol When i bought the cpu and mobo the bracket etc wasnt fitted to the mobo!!! I had to fit the retention frame and backplate myself to the mobo
Cob said:Is it glued on?
You can say what u like but I had to fit my backplate and retention frame to the mobo, I know cause I had to do it!!! and it came with the cpu!Concorde Rules said:It didn't come with the CPU, I can tell you that.
