- 10 Apr 2004
FrostFox said:To attach the backplate it had like double sided tape on it and I removed the protective cover and attached it to the mobo
You can say what u like but I had to fit my backplate and retention frame to the mobo, I know cause I had to do it!!! and it came with the cpu!
Ah its S754, with 939 you get the bracket.
But according to this picture: http://www.hardocp.com/images/articles/1082350875lk8SrXrQq3_1_4_l.jpg
the backplate comes with the motherboard.
With 939 the bracket comes with the mobo...
