- 26 May 2008
Just wondering if there is an average I should be seeing.
Since installing Windows and using the PC more, I have changed to the Arctic Freezer 36 CPU cooler, sitting here downloading a few games, browsing the forum, and seeing the CPU sit at around 80c seems a little high. Fan settings in Bios were on silent, GPU was around 41c.
I upped the motherboard fan settings to standard, now hearing the fans but temp still seems high at 75c-80c while a game installs. Now the game just completed install the CPU has dropped to 46c and system is near silent again.
Fitted the Freezer 36 with a pea sized blob of Noctua thermal compound. Case is an H500 with two Arctic P14 PWM up front, an Arctic P12 PWM in the rear, Arctic P12 PWM in the roof just behind the CPU cooler.
Bear in mind I have came from old 4770k CPU's running idle at around 30c odd with Noctua and BeQuiet coolers. So is this simply normal for AMD systems on air?
