I'm terrible at interpreting stuff from videos.can you not see all the flashing and flickering and motion blur you might need to view it on a larger screen
Hmm. My best guess is that it is some other issue, rather than the hardware itself? But, I've never heard of the APUs having poor visual quality on the desktop, so the next best thing I can suggest is trying to find a store that has either the desktop or mobile versions and they will let you have a play with it.No the problem is there all the time when in you tube and there is no card in that PC
It could be a conflict between the refresh rate of your TV and the FPS of recordings on YouTube, I guess?Im not really sure why it looks so bad maybe it just looks bad on my TV
Could you test it with another monitor/TV? I don't know what kind of OSD settings would influence that.Tried a lot of diffrent drivers but its still the same even tried another browser but made no diffrence maybe its as you say something to do with the TV not sure if there is a fix for it or buy a new TV
Fair enough!i don't have another TV to try it on i did have a look at the TV settings but i cant see anything in the settings to change. What I'm thinking of doing is buying the Ryzen 5 8600G and pairing it with a cheap board like the MSI B650 slapping some cheap ram in it and see if it works. If it don't work i can send it all back and take up golf
maybe try a cheap gpu in there first, and send that back instead, saves all the work,i don't have another TV to try it on i did have a look at the TV settings but i cant see anything in the settings to change. What I'm thinking of doing is buying the Ryzen 5 8600G and pairing it with a cheap board like the MSI B650 slapping some cheap ram in it and see if it works. If it don't work i can send it all back and take up golf
