One more notch would be the max voltage of 1225. It is stable at this voltage so far with no issues. Is it going to cause problems long term running at this voltage?
Cheers
How long is a piece of string? Its unlikely. Afterburner doesn't let you run silly volts through the card. It should be fine. Enjoy your over clock.![]()
Thanks.
Just had a massive session on Sleeping Dogs... Completing it infact! I did notice my GPU temp maxed out at 73c though. Not sure if I should be concerned.
Do I even have to have 'Run Afterburner at Start Up' ticked if I have 'Apply Overclock on Start Up' ticked?
Also - got my card WF3 7950 @ 1100/1500 - 1.13v. Heaven on Extreme doesn't go above 61'c.
Well for some reason my card keeps downclocking when plying games?
Any ideas?
Is this when over clocked? Have you increased the power slide to +20%?
Yes - while overclocked. Power slide is at +20%. Going to try upping the voltage some more.
1.2v safe you reckon?
Yeah a voltage bump might help. 1.2v is safe as far as i know.
1.2v may have solved it. Not had the problem since. No higher than 64'c, although fans get a little loud - but not noticeable with headphones.![]()
Weird upon reading this thread my OC has gone haywire with new 13.3 beta 2's. AB OC's wont apply, GPU-z is reading my card at 860/1200 when default is 900/1200. When I power up valley its reading out as 450/1200.
Going to try and reinstall the driver see if that sorts it out.
Might be worth completely un-installing afterburner. Reboot after uninstall, don't keep afterburner settings. Then reinstall.
Yeah, this clock obviously isn't stable. Just crashed to desktop during a benchmark. Don't understand because it was fine yesterday.
1175/1225. Which should I reduce first?
EDIT - In the Guru3d review for my card, the reviewer states this card can run at 1050/1425 on stock voltage. Is it a good idea just to set the levels at that and leave it be?
EDIT2 - Getting so frustrated now. Tried 1050/1425 as per the review on stock voltage but I got a BSOD after the 2nd run through.
Cheers
Cheers LT, must have installed new beta drivers with AB on at startup applying an Oc.
I had no idea over clocking took this much tweaking.
Seems fine being benched a couple of times at 1150/1200. Should I try and step the memory up now?
