- 20 Oct 2011
Current settings :-
fans auto - volts (mv 1275)power limit +5 % 1115 + 1725 - temp =77 = score 2160
Is the temp are fair temp or it running too hot ?!
Where should i be going from here MV wise , Core and memory speeds....what is the max score i am likely to achieve ? as i may just leave it set as it is if for example , i am only likely to achieve a 2 % or so further improvement.
I do not want to over stress my card , as it is 2nd hand with no warranty , but i would like to overclock to a good speed but not over stress it
One thing i have noticed is that if the fans are on full or on auto at the current settings the temp remains pretty much the same.
Advice please ...
My system
VTX3D 7970 (core voltage unlocked) x-edition
amd 8350 running at 4414 mhz
ram DDR3 running at 16gb 2052 (2x8gb Ballistix crucical pc3 12800 cl8 1.5v)
Asus MB M5A97 LE R2.0
windows 7 64bit
Evo 840 250 SSD HD
XFX PSU PRO 550W
Cooler Master Case
Software running
Latest Beta Drivers for graphics card.
MSI
GPZ
Heaven vally bench mark settings :-
Preset :custom
API : DX11
Quality : High
Tess
isabled
Stero 3d
isabled
Multi Mon : Disabled
Anit A : Off
Full screen : Ticked / On
Res : 1920 x 1080
Test reports :-
Voltage is unlocked already on my VTX3D 7970 X-edition , i have checked this using the test method on page 1
graphics card stock speed(1050 + 1425) , stock volts (1194) fan auto score 1923
fans auto - stock volts (mv 1194)1085 + 1575 = score 2035
fans auto - stock volts (mv 1194)1100 + 1625 temp = 72 score 2093
fans auto - stock volts (mv 1194)1100 + 1675 temp = score = 2123
fans auto - stock volts (mv 1194)1105 + 1700 temp 74 = 2133
fans auto - stock volts (mv 1194) 1115+ 1710 temp 74-75 = 2153
fans full 100% - stock volts (mv 1194)1115+ 1710 temp 74-75 = 2149 fans on full
Started to show artifacts ****fans full 100% - stock volts (mv 1194)1125+ 1725 temp 74-75 = 2166 fans on full ***
Scaled back graphics 100 % fine no artifacts ****fans auto - stock volts (mv 1194)1110 + 1725 - temp 70 = 2152 fans on full ****
fans on full - volts (mv 1250)1110 + 1725 - temp 74 = 2121
Power limit set to std + 0
Advice please ...
My system
windows 7 64bit
Evo 840 250 SSD HD
XFX PSU PRO 550W
Cooler Master Case
Software running
MSI
GPZ
Preset :custom
API : DX11
Quality : High
Tess
isabledStero 3d
isabledMulti Mon : Disabled
Anit A : Off
Res : 1920 x 1080
Test reports :-
