I dont think he bought it from ocuk as he mentioned in post 267.
Did you go for four again?
the power draw 'issue' doesn't need to be a reason for return under the long distance trading act.
As long as he has all of the packaging and the card is in good condition, OCUK should refund it.
Once funds have cleared, there is nothing stopping the guy ordering an AIB
I'm within 14 days of course, only got the card on Thursday last week. Was from a different retailer starting with 'E' ending with 'R'. would have got from OCUK but for some reason couldn't see the RX480's on OCUK's website using search function.
Will see what tomorrow brings with this driver update otherwise I will send it back - happy to foot the postage bill either way.
Company burning the midnight oil
AMD is burning the midnight oil fixing a problem on its new Polaris card which it thought was not an issue last week.
Last week reviews started complain that the Radeon RX 480’s power draw was enough to fry lower priced motherboards. AMD denied it saying that the card had been signed off by all the important standards crowd.
AMD fanboys claimed that it was all part of a conspiracy by Nvidia fanboys to damn the card to oblivion. We were inclined to agree, given that only one reviewer had noticed the problem, and it could easily have been a card issue.
But then the reviews started to confirm the problem – the 150-watt card used on average 168W under load. The card drew 90W over the motherboard’s PCI-E slot, far exceeding the 75W maximum the slot is rated for.
German site Golem.de observed identical behaviour, as did TecLab and PC Perspective. PC Perspective discovered that AMD’s card drew 7 amps over the PCI-E slot’s +12v rail, which is rated for 5.5 amps maximum. The Radeon RX 480 also overdraws the board’s solitary 6-pin power connector.
While 95W spikes through the PCI-E connector can be handled by most motherboards sustained power levels that high could potentially fry a motherboard’s pins and connectors.
AMD says a software-based fix is incoming. It said that it has identified select scenarios where the tuning of some RX 480 boards was not optimal.
“As you know, we continuously tune our GPUs in order to maximize their performance within their given power envelopes and the speed of the memory interface, which in this case is an unprecedented 8Gbps for GDDR5. Recently, we identified select scenarios where the tuning of some RX 480 boards was not optimal. Fortunately, we can adjust the GPU's tuning via software in order to resolve this issue. We are already testing a driver that implements a fix, and we will provide an update to the community on our progress on Tuesday (July 5, 2016).”
If the software fix involves reducing the power draw for the RX 480, that’ll most likely lower performance in the reference editions of the card as well, especially since Polaris’ performance is closely tied to the card’s power limit.
This all could’ve been avoided if AMD had simply used an 8-pin or 2x 6-pin power connectors. If it does fix all this smartish it could have a really good card on its hands.
So, basically, this is potentially AMD's most disastrous product launch ever and the issue is unlikely to ever be fully fixed for original 6-pin cards.
GG AMD then.
I trust Gibbo more than some random reviewers on the internet (one of which looks like he is having a heart attack whenever he has to say something pro-AMD). Yet to see any killed motherboards, or burnt out boards as all the naysayers keep saying.
AMD problem = Major problem
Nvidia problem = Small problem quickly tucked under the carpet
All this BS from both camps is doing my head in.
I'm in the exact same situation with you, only I bought mine elsewhere. The various reports on the successes of undervolting cards do look promising though.
On a more general note, if hypothetically, my 480 did still ruin my motherboard does anyone know how easy it would be to get compensation, and who would I be needing to contact?
Yeah I agree, it's not a clear cut problem and hasn't been looked at objectively. I am still a bit surprised with Nvidia's offering, and why on earth they decided on 3/6GB. If they went 4/8GB and reduced prices to compete, I could have seen them destroy one of AMD's most hyped releases ever, but they didn't.
i seriously dont get it. you are both complaining of a problem that isnt a problem. almost all other cards that have ever been made use more than the "limit" of the pcie lane.
what are you hoping to see different than what you have now? how do you even check how much power is going through your pcie lane?
None of those cards draws more than the limit from the PCI-e socket itself AFAIK while the 480 has been proved to be capable of drawing upto something like 92 watt sustained load which is around 40% over the spec.
Aside from that you have 3x 0.7mm traces carrying 12v from the socket which I believe are 1.37mils (might be wrong on that) - which gives a max current rating of ~5.46 amps - hard science means things don't go well when you start going much over that and IIRC the 480 has been demonstrated at 7.6amp draw from the socket - to pretend there isn't a potential problem there is naive at best.
if you ever want to hear the truth about a product,good or bad..listen to someone who doesn't have a vested interest in that product.
whenever I hear in 1 ear that there are no problems by a salesman,and I hear the opposite in the other ear from an independent party..i know who I believe.
